How do i find the Window Sticker for `65 vette - NCRS Discussion Boards
  • Bruce G.
    I am new to corvettes, where can i find the buildsheet and the window sticker to my 1965.
  • William C.
    • May 31, 1975
    • 6037
    Re: How do i find the Window Sticker for `65 vette
    Buildsheets were not typically included with the '65 Corvette, and the original window sticker was either removed by the dealer or the original owner. Your guess as to the location of it now, however replacement window stickers are readily available from reproduction houses, but they mean little as they are made to customer order, without an insight as to the actual specificatons for the car when built.
    Bill Clupper #618
    • Eric J.
      • March 1, 1980
      • 771
      Start you own book now..
      Bruce, As Bill stated it is not readily available. 1st thing is to start with a good resource like the TIM/JG (Judging Guide) or the Corvette Black book. THen document everything your car has right now. (Document the trim tag etc) I take digital pictures of every clue and keep them in a 3 ring binder. Since you don't know what it had this most likely will be a moving target. Like when I popped the rear drums of of my 63 SWC and discovered it had J65 Metallic brakes! Or like the time I found all the correct firewall/engine compartment fastener holes fo FI and the brake duct "tusk" holes for RPO 687 on my 61. Took years to find those. look for signs of other possible options. Also track the ownership history go as far as you can. keep that in the binder. do occasional google searches on your VIN. Run a driveline ad seaking info etc. DOcument what you do (receipts etc) Keep them in your binder. Pretty soon, you become very comfortable with the options it came with. You will also have a book that demostrates why you believe it is so. Eric #3,182
